L
1 Question:
In a process, it's known that is better to not use fieldbus for safety reason (it is not analog). Considering this, the question is if the reduction of wiring in process control could be an advantage by itself or it could be an advantage only if coupled with a reduction of all the wirings (safety system too).
2 Question:
Why with Fieldbus it is not easy to insert a new device but you have to recalculate the length of the cable? The impedance has to be setted before?
3 Question:
Do you have any pictures or diagrams showing the logic of fieldbus? Also compared with DCS?
Thank you for your help on these questions.
2 Question:
3 Question:
